What am I looking for here....
Tiwaz
57
Miami Beach
Before purchasing a tachometer,
(which by the way if anyone has one for sale with canon connector let me know)
I would like to know if the harness is good so a "Plug n Play" situation would occur.
In the picture is the connector hanging by the windshield wiper motor and two of the wires (27P and 57L) are self explanatory, respectively +24V and GND but the question is:
What would I be looking for on the third (2D) wire with a multimeter....?
Would it be some AC voltage...? DC voltage...? some kind of impedance, how would I know that 2D has what it takes to make the tachometer work...?
FlameRed
626
Florida
Sorry, I don't see any picture in your thread...
This is of little help to you as mine was a M998 with a 6.2 and there was no harness for a tach. So on the 6.2, there is a sensor on the very back of the engine with two wires coming out of it. The tack connects to these two wires as the data source. Ignition source is important or the engine meter will run up.
Then there is a +24V ignition source needed, and ground, and a source from one of dashboard lights so the tach lights up with the other guages on the dash.
I just used posi-lock tap connectors into existing wiring. :recovry4x4:
DREDnot
447
Phoenix, AZ
Assuming you have the M1151...The tach harness is plug and play...all you need to do is modify the connector on the generator voltage regulator AC tap(2A). Cut the ring connector off and install a packard (military) style connector to accept the 2B wire from the tach harness. The tach harness 2C ring terminal goes to the generator tap terminal now.
This is the instruction sheet to install a military tach kit.
veiws G, H, K, K1, and L show you how to modify the wire from the AC tap on the generator and plug in all the rest. The ground wire goes to the ground at the back of the instrument cluster next to the high beam lamp. I just successfully added a tach last week and this sheet was the "rosetta stone" for me. Once you study it it makes sense and was easy
