What Are DEMIL Codes?
peapvp
1,219
Basehor, KS
DEMIL codes are assigned to DOD personal property that indicate the required degree of physical destruction, identifies items requiring specialized handling or processing, and identifies items which do not require DEMIL. DEMIL F and other codes can require additional guidelines to be followed prior to turn in to DLA Disposition Services.
The DEMIL Codes below are listed as the Highest Severity to the Lowest Severity in DEMIL Coding
Code Explanation
CodeExplanation
GUSML or CCL Military Items – DEMIL required – ammunition and explosives (AE). This code applies to both unclassified and classified AE items.
PUSML Items – DEMIL required. Security classified items.
FUSML or CCL Military Items – DEMIL required. Item managers, equipment specialists, or product specialists must furnish special DEMIL instructions.
DUSML or CCL Military Items – DEMIL required. Destroy item and components to prevent restoration or repair to a usable condition.
CUSML or CCL Military Items – DEMIL required. Remove or demilitarize installed key point(s) items as DEMIL code "D".
EDoD DEMIL Program Office reserves this code for its exclusive-use only. DEMIL instructions must be furnished by the DoD DEMIL Program Office
BUSML Items – Mutilation (MUT) to the point of scrap required worldwide.
QCommerce Control List Item (CCLI) – MUT to the point of scrap required outside the United States. Inside the United States, MUT is required when the DEMIL integrity code (IC) is “3” and MUT is not required when the DEMIL IC is "6."
AItems subject to the Export Administration Regulations (EAR) in parts 730-774 of Title 15, Code of Federal Regulations (CFR) (CCLI or EAR99) and determined by the DoD to present a low risk when released out of DoD control. No DEMIL, MUT, or end use certificate is required. May require an export license from DOC.
General Note
For additional information on DEMIL codes and use, see DOD MANUAL 4160.28, VOLUME 2 DEMIL Coding
