VP0985
- 54
- 18
- California
Just looking to pick everyone's brain to see what the major differences are between these 2 vehicles.
Sent from my SM-G990U using Tapatalk
An M998 with a winch is an M1038…there Are far less models now than before, M1043,M1044, M1045,M1046…-10 operators manual shows all variants and differencesI’m surprised there aren’t more differences, seems like no real need for a separate model
Mine is one of the 15,500 pound ones, and I'd love to know why.The springs could also be different, I should check the manual, because some 1151A1s are rated at 15,500 GVW, while the 1167 (also REV) has a 13,100 GVW rating, which in turn may affect the ground clearance by 1-2 inches, as each model has some slight different clearances, and also from 1165A1, which is from the same family and rated at 12,100 GVW.
I am saying “some” because the linked data sheet shows the 1151at 12,100GVW, butI saw many on GP rated at 15,500 GVW.
So is the thought those with 15500 GVW are taller as a result considering the potential difference in ground clearance.The springs could also be different, I should check the manual, because some 1151A1s are rated at 15,500 GVW, while the 1167 (also REV) has a 13,100 GVW rating, which in turn may affect the ground clearance by 1-2 inches, as each model has some slight different clearances, and also from 1165A1, which is from the same family and rated at 12,100 GVW.
I don't have any exact data and couldn't find any specs on the springs in the manuals, on paper only, it looks like this:So is the thought those with 15500 GVW are taller as a result considering the potential difference in ground clearance.
I can do that when I get a chanceMaybe someone that has the 15,500 rated model could measure and let us know the distance from the wheel hub center to the bottom of the fender, front and rear.?
Did you get a chance? I’m curious about the differences and clearances as well. Thanks!I can do that when I get a chance
