What are these rims for?
maddawg308
734
Front Royal, VA
Did you measure them? They definitely look military-ish. I'd buy them all if the price was right, and I had money. :)
1,806
Assuming they have the correct bolt pattern, you will need to flip the rear hubs with depth of offset.
M1075
Oklahoma City
They almost look like they would work on a bridge truck. I would be hesistant to use them on a M52, not knowing if they would get the tire far enough away from the frame for steering.
citizensoldier
Northern Michigan. Smelt City
Would this work perfict if you flipped the hubs like Kenny said? For some 1600/20's on a 5 ton? Would this cause bearing issues on a 5 ton if you flipped the hubs? Man if these would work like that I could use a set for my M51A2..
M1075
Oklahoma City
These should work fine in the rear with a hub flip. But since the backspacing is so much more than a normal combat wheel used for singles, there could be some rubbing issues in the front when turning (especially 1600s). If they are cheap enough, they might be worth a shot (don't forget the cost of new tubes/flaps). They do look ideally suited for a bridge truck (w/ spacers).
JasonS
131
Eastern SD
They are $150 each; they don't want to budge unless we buy a huge quantity. Their relatively high prices have resulted in them having some unique items in their salvage yard.
