racing4funn
- 0
- 16
- Chattanooga Tennessee
I've seen the C&CE kit and want it but found an old post that said considering the size of bed and capacity of these trucks it was easy to overload the lift abilities of their kit/actuator
It also depends where the hoist is mounted. The farther back you mount it, the steeper angle it will dump, but the less force it will have. Hinge placement also plays a role in hoist capacity. Any bed hanging over past the hinges will help with hoist capacity.The issue of how much it will dump is generally not dependant on the hydraulic pump, its a matter of if the lifting cylinder is a large enough diameter to create enough lifting force. The c and c kit cylinder is probably too small.
Excellent point, I suppose I just assumed it was a 939.A lot depends on what truck we are talking about. This is in the 5-ton forum so I assume a 5-ton but what model?
If we are talking a M939 truck, there are factory PTO kits available that will bolt right up (used to run the winch on winch trucks). When you get to the older 5-tons, you have to get a little creative because there is no factory bolt-on kit.
It's a M939 with a winch so I guess the battle is half won. I can just T into the out and return lines and use. Wall valves for redirecting. All I NEED to come.hp with is a cylinder and frame.
Yep! Your halfway there! Start scannin the area for a old dump truck or grain truck that looks like it hasnt been used for a while!It's a M939 with a winch so I guess the battle is half won. I can just T into the out and return lines and use. Wall valves for redirecting. All I NEED to come.hp with is a cylinder and frame.
