- 191
- 65
- 28
- Austin, TX
I know bad injectors can cause a knock but I'm lost on physically what is going on to cause the knock. I've searched the forum and internet but haven't find a good answer.
My understanding is engine knock is caused from pre-detonation of fuel that causes an abrupt increase in cylinder pressures, usually in advance of when it's supposed to burn. The rapid increase in pressure is the actual knock that we hear. I understand this is easy to cause with gasoline engines where the fuel is already introduced during the compression portion and the fuel/air mix can detonate from hot spots, bad fuel, etc. but I don't understand pre-detonation on diesel engines where the fuel is injected 'always at the right time'. I think this is especially true on the NHC 250 where the mechanical system that fires the injector (cam/rocker) isn't real easy to advance. I believe a failing mechanical injector will only inject less fuel or later in the stroke so I'm lost on how detonation can occur.
I'm sure there's a simple explanation...so feel free to edge-u-ma-cate me.
