What coolant & for MEP-802a? Precharged nitrite type or just green heavy duty type?
Chrispyny
12
I'm literally at the parts counter and dont know which to buy and how much. Any help would be greatly appreciated guys. Thanks
jimbo913
35
Maryland
Inhibited ethylene glycol antifreeze (MIL-A- 46153), is what it calls for. I believe that is standard corrosion inhibtor type you find at any auto parts store.
Chrispyny
12
Drained a little less than a gallon from the radiator. Tried to turn the petcock on the engine drain but it's tough to get to and although my fingers got to it, i tried as best as i could to turn it and it wouldn't. Dunno how any tool fits in there to turn the petcock. It's in a wierd spot behind the belts.
Anyway, the 802 holds a little more than 6 quarts of coolant. I drained say 3.5. So i got more than half. Whats weird is the old stuff seems almost strait coolant from the green color. No premix. I chose the 50/50 mix good to -35°F. That should be good. I think I'll run it a bit, and do one more flush. that should clean it out very well and still provide better than -35°F with some of the old stuff still in it.
Either way even with only 22 hours on it. The coolant was dirty. So it was certainly worth the effort.
Thanks for all your quick answers guys.
Daybreak
2 Star Admiral
770
Va
Howdy,
Regular car coolant is not the same as a heavy duty diesel coolant. Usually a diesel engine uses a heavy duty coolant with pre-charged SCA. There are lots of green coolant brands out there. Although with today's technology, I am sure any will probably work good enough.
That's why I didn't want to get crazy, I already have John Deere Cool-Gard II on hand.
MEP-802A 6.2 qts coolant
John Deere Cool-Gard II TY26575 –pre-mix, 1-gal. (3.8 L)
Here is a good pdf brochure from Cummins Filtration on antifreeze/coolant
Chrispyny
12
Howdy,
That was my concern also regarding the coolant. But i went to both adcance auto and napa next door, and neither had green heAvy duty diesel coolant. Any precharged diezel coolant (which i would have chosen immediately) they had in stock was pink. There was NO coolant precharged with sca (nitrites) that was green. But there was green coolant which said it was safe for diesel engines,mso thats what i grabbed. I'm guessing i should be good.
I think i'm still way ahead considering how the other stuff looks! Yuk.
Korgoth1
radford, va
Deere stuff is top shelf. The prestone will do just fine, change it in 3 years, good to go. My 004, and tractor have it in them, over 3,000 hrs on the ford and 2,000 on the mep, stuff is still crisp and clean...My bike came from the factory with red silicate in it, when I rebuilt the engine the silicate had crystallized, settled out, making a sand in the bottom of coolant passages. I would not recommend the silicate based coolants.
The block drain can be got if you a creative with an adjustable wrench, just slide it over and use it for alittle extra torque to get the sucker loose, for future reference.
csheath
213
FL
I will kick this back to the top. The manual says to use MIL-A-46153 and water. I can't find any off the shelf antifreeze that has the military spec listed. The engine design in my 803 doesn't look like a wet sleeve design but I would think to be on the safe side a heavy duty diesel rated antifreeze would be best. Of all the brands and descriptions I've seen the Fleet Charge SCA Precharged Fully Formulated Antifreeze & Coolant look best to me.
http://www.tractorsupply.com/tsc/pr...mulated-antifreeze-coolant-1-gal?cm_vc=IOPDP1
My second choice would be the Shell Rotella ELC Antifreeze.
http://www.tractorsupply.com/tsc/product/shell-rotella-elc-antifreeze-1-gal?cm_vc=-10005
Light in the Dark
5,910
MA
@Chrispyny... I've got the same issue on my 802a. I was in the midst of draining all fluids this past fall for the first time, and I can't even get my **** arm close enough to reach that block petcock (forearm hangs up on pulleys and belt). So I have an 802a that is partially drained, and ready for me to fight with it again when I can get someone with a slimmer arm over to reach the **** thing! Fluid was filthy in mine too... so I am not OK with just leaving it like this and topping off.
And to the heart of this thread... I have standardized all my units on Rotella ELC.
JRM
12
Brightwood, Oregon
Iron engines should have heavy duty green, stay away from those HOAT pink and orange coolants that use Organic Acid's as they are intended for Aluminum radiators and engines and will eat solder joints up pretty quickly, I found this out the hard way by trying to over maintain my old Toyota truck- that OAT coolant ate my heater core in a few months :(
Guyfang
23,970
Burgkunstadt, Germany
We used every color of he rainbow in the army. BUT, green was by far the preferred type. In post #5, the Prestone jug, well, I believe I have opened about 10 million prestone containers in my life. Good stuff, and I won't say more.
About that petcock. I used a homemade tool. Made it out of a real short 1/4 inch extension. Put a ratchet on it. I cut and filed on it, (made three before it worked right) till it would stay on the petcock handle, then shed blood getting it open Often broke it also. Then its remove a bunch of crap to get in there and replace it. Someone needs to go to the electric chair for that bit of engineering.
csheath
213
FL
I haven't even found the block drain. Not on the engine or in the engine manual. Anybody got a pic or description that shows where it's located?
Light in the Dark
5,910
MA
You have to reach through the pulleys and belt at the front of the engine... its right on top. If you go the side of the case that has the black rubber radiator drains, you will see they T. One comes down from the side of the radiator, and the other just follow back towards the engine with your hand. Will lead you right to the bugger.
csheath
213
FL
I reached mine easier with the belt off, and also used a leaf blower to blast the remaining yuck out by pressurizing the top of the rad
This probably explains why the belt was loose on my unit when I got it.
csheath
213
FL
Looked at this when I got home today. Looks like the best way to get at it is to remove the tension bolt completely and rotate the alternator down out of the way.
I decided to get the Rotella ELC antifreeze.
