m1garand_man
- 0
- 0
- Ft Wainwright / AK
So I know that a lot of this is covered in other threads and I am fairly familiar with the CUCV configuration of the 6.2l Detroit but not the HMMWV one that I will want to put in my M1009 CUCV to replace my current blown engine.
If you have been following my other threads you have read that I have an internal coolant leak somewhere in the block or possibly water pump and I'm tired of messing with it especially after I thought it was the head gasket(s) that was blown. So I will probably buy a pull out from white owl surplus.
Here's what I know I will have to switch over to the HMMWV 6.2 to get it to work in my M1009 tell me if I'm missing anything.
1. Intake manifold
2. Exhaust manifolds
3. All sensors
4. Vacuum pump (will my vacuum pump just drop in where it belongs on the HMMWV engine or do I have to install the drive gear or other components from the CUCV engine to get it to work? Also can I orientate it to the same position it was in the CUCV engine and still have it work properly?)
5. Injection pump
6. Glow plugs
7. Water pump? (Is it true that the HMMWV one runs in the reverse direction from the CUCV one? Will the CUCV one bolt on?)
8. Pulleys.
9. Tensional dampener? (Dose this need to be changed over?)
10. Studs for power steering pump (How do I get those out of my CUCV heads anyway?)
11. Alternator and bracket (will they bolt on correctly or do I have to modify anything?)
12. Power steering pump and brackets (will this bolt on correctly?)
13. Oil pan (assuming I get an early enough HMMWV engine I'll be fine but what If I get one with a new style casting? will the HMMWV pan clear the suspension parts in the m1009? If not where can I get a pan and dip stick that will work?)
14. Oil pump (assuming that I need to and can put my CUCV pan on the new engine.
15. Oil filter mount (How do you change this over any way or can I leave it in the horizontal HMMWV configuration?)
Am I missing anything else?
1. Intake manifold
3. All sensors
5. Injection pump
6. Glow plugs
8. Pulleys.
