What do these attach to?
Vapor Trail
264
Kentucky
Can anyone tell me where these attach for my parking brake system. I don’t have a vehicle to look at and my disassembly pics don’t show . The frame or the underside of the body?
Retiredwarhorses
4,177
Brentwood, Calif
If you don’t own a truck, why do you care where they go?
But here goes, they go on the casted frame support
On the rear/front cross member where the rear radious rods attach. A long 1/4-20 bolts passes through, 2 cushion clamp holds the brake cable to prevent chaffing the cable on the lower control arm.
Vapor Trail
264
Kentucky
Thank you! I thought that’s where they went but it didn’t seem like I could get them to fit in there properly. The TMs show the parts but not how they configure or attach to anything. I do have a M1123 and we’ve actually talked on the phone a few times but it’s in pieces . The build thread is in the Modd’d Humvee forum down below. It’s weird to me because the brackets here are marked opposite what the braces for the radiator supports are marked. On the driver side the radiator support is marked right and the parking brake bracket is marked left. I would think everything on the drivers side is left
Retiredwarhorses
4,177
Brentwood, Calif
sorry, misunderstood when you said you didn’t have a truck…
