?what does or did it do?
martinsaunders06
gloucestershire,uk
under the hood of the 816 wrecker is a plastic bottle/container fiitted to inside of engine upper side panel by aircleaner-what is it for please=mine does nothing,and also in the tm it says the front axle cv joints need lubing via pipe plug infront swivell housing= is this correct or it lubed from the axle gear oil?
martinsaunders06
gloucestershire,uk
?alchohol bottle?=yeah it has remains of a small hose on lid but goes nowhere, i know its daft but looks like it should be a washer bottle or coolant overflow.what would alcohol bottle do?
DavidB
27
Southeast Wi.
Alcohol bottle is jar shaped another plastic vessel could be windshield washer resivor.Check for wire handled pump under dash.
DavidB
DDoyle
80
West Tennessee
martinsaunders06 said:
also in the tm it says the front axle cv joints need lubing via pipe plug in front swivell housing= is this correct or it lubed from the axle gear oil?
Not lubed by gear oil, the TM is correct.
Armada
Buick City, MI
Keep alcohol in it while you're running the truck. The air is drawn through the alcohol and the moisture is removed. A bottle will last quite awhile.
beaubeau
Salisbury,N.H. 03268
I got one of those in my deuce, but the line goes in the cab,with a nipple on it!! I keep 90% Vodka in the Bottle!!! Just Kidding guys!! Good info on the Item though!! Good luck, Phil ,
emr
25
landing , new jersey
THATS FUNNY!!LOL!!...Randy
