What does this rim fit
sermis
17
Temple, TX
I scored another 15.5 XL and it came with a rim. It was a real pain to get the tire dismounted. The lip inside the rim that holds the "O" ring stopped the tire from coming off. After a lot of sledge hammering I got it. I know why they have started replacing the wheels and tires as a unit.
The rim has an 11" center and about a 13 1/4" bolt pattern.
sermis
17
Temple, TX
I did not see any numbers on the wheel but it also has real thick paint. The rim has a single valve stem and not the central inflation system.
M1075
Oklahoma City
That may be a rim from M1076 trailer. I do not know what else the Army runs 15.5s on. Let me do some measuring and I can tell you for sure. If it is, I could sure use it if you don't.
sermis
17
Temple, TX
I have no use for it. Wish I would have known. There was another good rim there I did not get. I thought about cutting the Deuce center and welding it in.
DMgunn
SE North Dakota
Are the HEMTT rims compatible with a 5 ton (10 hole Budd)? Either the search feature isn't working or I have spelling issues, but I can't find anything, although I'm sure it's been covered 1,000,000 times. I need a few super single rims.
jwaller
19
Columbia, SC
sermis said:
jwaller said:
the wheel in the second pic I just installed on my 818 and it fit perfect with 1600 xzl's
Can you post up some PIC's with them mounted?
yes I can. the studs may be a little shorter than stock but I'm comfortable with it. I feel there is enough stud coming thru the nut to be of sufficient strength to be held.
I just put the Hemit wheels with 16:00 20 XZL's on the M819 and the stock front wheel studs are to short. its not that big of deal to change them as the front wheel bearings probably could use cleaning and repacking anyways. i did not feel comfortable with the stud that would not fill the lugnut. i feel that the lugnut was designed that thickness for a reason.
jwaller
19
Columbia, SC
I've always been told that as long as you have at least the width of the bolt in threads into the nut you are fine. I believe this to be true in this case. true the stud doesnt come all the way thru the nut but until I get the combat whees mounted I can live with it.
