M35A2usmc
- 0
- 0
- Upstate, New York
Hi was wondering what you have swapped in instead of the 6.2, how hard was it and would you recommend it?
Thank youBesides a 6.5TD
https://www.youtube.com/watch?v=K3yohoCqD2E
http://www.steelsoldiers.com/showth...or-a-6-5-turbo-charged&highlight=engine+swaps
this for a 4Bt http://www.steelsoldiers.com/showthread.php?98893-4bt-in-1009&highlight=engine+swaps
http://www.steelsoldiers.com/showth...ison-divorced-205-swap&highlight=engine+swaps
How is the 454 working out? Was it a hard swap to do, and how long would you say it took?Put a 454 in my M1028A1 and am working on logistics to put a 496 aka 8.1 in my M1031.
Thank you, will do if or when the time comes I want or need to swap it if I go this route.Nope it was easy...Its the same engine bolt pattern and motor mount.
I swapped out the frame engine mounts I happened to have them I didnt go looking as they are obsolete from gm.
You would be advised to look to a wrecking yard for these mounts FYI: these mounts are the 1 of 3 in the mount that uses 6 7/16 bolts In pairs of 3, bolts to the frame and crossmember.
Sourcing the gas eng pullies and hang on parts alt, power steering pump (w 2 returns, water pump. Keep in mind none of the hang on parts from the 6.2 will fit the 7.4
.If you have questions pm me.
How hard was the swap would you say?I have a 12v cummins in place of the 6.2
Nothing is showing up with the picture or the link?
free image host
I wouldn't say it was hard but overall there was a lot to do, from the nv4500 install to the cilivian wiring harness that I put in it was just a lot of work.
Yes it does thank you!does[/URL] that work?
A pic of a 454 and the second pic is a tall deck BB Chevy with dual alternators.Hi was wondering what you have swapped in instead of the 6.2, how hard was it and would you recommend it?
