What gauge of wire is the glowplug wiring harness?
linx310
texas
I want to replace my glow plug connectors with spade plugs so I can use my AC Delco 60gs.
After work I am going to run to the hard ware store and pick up some insulated female spade connectors.
Does any one know the wire gauge size so I can purchase the correct spade connectors?
14 gauge?
Warthog
224
OKC, OK
You have been here long enough that you should be able to figure this out yourself....;-)
From the glowplug wiring diagram in the tech manual appendix E-7 or F-7
the wires are listed as .8 GRN-509(E-H).
Using the cheat sheet at the first part of the Troubleshooting Section of TM 9-2320-289-20 manual, it tell you that the wire is a:
18 gauge Green fusable link (heavy walled silicone over cross linked polyethylene
So to asnwer your question, the wires are 18 gauge.
linx310
texas
Yea I saw that first page (wiring diagram). I did not know the table existed to tell you what gauge it is and what the .8 stuff was.
Learn some thing new every day....
