What gauge wire for front wire harness?
paramedic7831
Thomasville, Georgia- USA
wsucougarx
65
Washington State
Most of the wire you find in a deuce is going to be 14 AWG. But use either. I found 500' spools of 12g for $30 shipped on ebay two years ago. So all my patch jobs are with 12 AWG. Man I wished I would have bought more!
Yes those are the correct connectors
paramedic7831
500 feet? I was thinkin I needed like 50 feet?!? Just need to pretty much rewire everything from back of engine ( not firewall) and up to headlights.
** Also do I need to use this particular wire PRESTOLITE? Or can i just use any 14 or 12 gauge AWG? I searched 14 gauge wire on ebay and showing lots of 14 gauge speaker wire? can I use this? seems like the original wire is rubber with some sort of cloth inside I'm assuming insulation.
armytruck63
9
Redlands, CA
Don't use speaker wire. It will not stand up well to the heat in the engine compartment.
There is a type of wire insulation that is resistant to gasoline etc., but if your wires are out of the way of the fuel system, this should not be a concern.
hndrsonj
Senior Chief/Moderator
362
Cheyenne, WY
IIRC, there is a front harness (I think for the 427 trucks) that sells really cheap. It usually is under $50. Buy it and take it apart for the wire and connectors.
AN/ARC186
15
Graham,Washington
paramedic,
You don't need to use the prestolite wire, I don't like it much myself. I use Ancor marine grade wire, it looks close to the original but has a thermoplastic jacket that can handle the temps and oils under the hood. Ancor | Marinco
just my 2cents
