what Happened to my M1101
DamiansAR15
Mercer Island, WA
So I got a 2009 Silver Eagle M1101 trailer from GovPlanet. I got it shipped on a trailer and was working on it, e.g. LEDs, wiring harness, painted, bed liner, tagged it, etc... When I was moving it around on my property and neighborhood, it was rolling fine. I was going to take it to a local tire store to switch out a tire (flat spot that looked like someone dragged it around the parking lot with break on) and pack/grease bearings. Well, the whole **** wheel came off! Luckily, I was at the entrance to a parking lot in local park. It looks like the entire axel was recently replaced as it has a silver Schutt tag on the axle with a part date of 2017.
Not sure if I need a new rim or if it was a bearing issue that needs to be replaced. Also, can anyone suggest a good place to get parts, if you can tell from the picture what is needed?
Thanks for you thoughts on this...
tobyS
835
IN
Your brake parts are not in their proper position, are any of them obviously bent? Will they go back into position? Looks like the axle will clean up and you may need a hub, bearings and (maybe) brake drum. With the bearing races out, can you clean the hub to work again?
Get bearings for the other side while your doing it.
DeadParrot
47
oklahoma city, ok
One thing I don't see is a cotter pin for the castle nut. Could explain the wheel falling off. Please check the other side before moving the trailer again. Possible whoever built that axle missed that step somehow.
NDT
6,391
Camp Wood/LC, TX
I sure don't see much grease on the remaining bearing. Maybe someone assembled it dry.
DamiansAR15
Mercer Island, WA
I also connected to my mechanic and he mentioned that there was not any grease on the bearings, which seems to align with earlier posts, e.g. burned up the bearing... My mechanic is working on getting bearing parts and I have a bad break line. I also will need to flush/bleed Dot5 brake fluid, as I think there was water in the brake fluid, e.g. found crack in cheap plastic cap.
Thanks folks for thoughts/feedback...
Tinstar
1,763
Edmond, Oklahoma
Now you know why guys check the bearings, etc when they first get them.
Bad bearings, loose nuts, missing parts and no grease.
