maxtor
- 3
- 0
- California
A while back, we purchased a 2011 M1101 trailer. I took off the wheel and brake drum and checked the bearings for grease. Before I did this, I checked and found out that the M1101 wheel seal was CR22532 which is the same as a Auto Xtra
412920. Napa had the CR for a little over $22 each. Summit Racing has the Auto Xtra for $4.97 each.
So I purchase two of the Auto Xtra. After checking on the bearings on our M1101 I found that they were more than adequately greased.
Then we purchased three M116a3 trailers and I found out that they also took the same bearings and seals as the M1101 trailer.
After checking the bearings on one of the M116a3 trailers, it needed grease.
I could not save the old seal, so in went two new seals and I cleaned and greased the bearings of the M116a3.
I am going to modify one, to pull behind our Jeep.
