What is a good Snatch block to use with a m818 and 20k PTO winch?
cwedge411
Boston/Ma
Just wondering who makes a good and more importantly rated snatch block for a 5 ton with a 20k pto winch?
I see a few that were rated for 16k winches, but Id like to have one that rated the same or higher. In these cases I don't like to live dangerously haha.
TIA
winfred
9
port allen la
i saw a few bigger units on ebay when i was shopping for the one for my deuce, IMG_3574.jpgIMG_3580.jpg next to the beefy hook from my 18k warn
edit, i just checked and "large snatch block" brings up a few military blocks, not sure how big a block you need but you can always expand the search from there if those arent good enough, i think one had a 10" pulley so that outta be a healthy one
rosco
Delta Junction, Alaska
Best to have one with the sheave groove size, rated for the size line that you'll be using. 5/8" groove, for 5/8" line. At any rate, it doesn't take much of a winch job with snatch blocks, that after you've set up the pulls, two or three times, using most of the winches capacity & dragging the stuff around, especially in mud or snow, that you'll be thankful for not having an over seized block to drag around with all that line. I'm glad that I got through all that stuff when I was a young man.
EO2NMCB
23
DeSoto, MO
I picked one up on ebay, 10t block for 5/8 line off ebay last month, nos , 150 with free shipping. Was best deal I could fine. They are heavy gotta be at least 50lbs
