What is AMMPS generators
Daybreak
2 Star Admiral
760
Va
We had MEP-003 10kw
then we had MEP-803A 10kw
we now have MEP-1040 10kw
Advanced Medium Mobile Power Sources represent the third generation of Department of Defense military standard generators. AMMPS are replacing second generation Tactical Quiet Generators, which have a 25 year old design, and providing significant operational improvements that greatly decrease the logistics footprint on the battlefield. The current family of AMMPS consists of five versions: the 5 kW, 10kW, 15kW, 30kW, 60kW generators. The AMMPS family:
  • Delivers fleet weighted average of 21% improved fuel efficiency over legacy systems
  • Increases reliability (750 hours mean time between failure), maintainability, and transportability
  • Reduces infrared signature and noise (less than 70 decibels at seven meters)
  • Provides 52% commonality of parts across all sizes of AMMPS
  • Incorporates military ruggedized commercial components
  • Minimizes weight by 10% over previous generation, as well as minimizes size;
  • Improves maintenance intervals (500 hours for 5 kW, 10kW, and 15kW; 750 hours for the 30kW and 60kW)
  • Reduces electromagnetic interference; electromagnetic interference protected
  • Improves sustainability; operates at rated loads in all military environments
  • Is capable of starting and operating on common fuels (diesel/JP-8 ) in extreme climatic and tactical military environments
  • Meets Environmental Protection Agency Tier IV Interim Compliance
  • Includes built-in diagnostics/prognostics for troubleshooting
  • Features automatic paralleling and synchronization; simple two button parallel
AMMPS MEP-1040 10KW Generator info mode =I 50/60Hz
NSN 6115-01-561-7455
10kW MEP-1040/1041 3 cylinder, 1.5L Yanmar 3TNV84T
NameValue
MOUNTING TYPESKID
OVERALL LENGTH55.000 INCHES NOMINAL
OVERALL HEIGHT36.000 INCHES NOMINAL
OVERALL WIDTH32.000 INCHES NOMINAL
III CURRENT TYPEAC
FREQUENCY RATING50.0 HERTZ MINIMUM AND 60.0 HERTZ MAXIMUM
END ITEM IDENTIFICATIONMEP-1040
UNPACKAGED UNIT WEIGHT995.000 POUNDS
AC WATTAGE RATING10.0 KILOWATTS
CRANKING VOLTAGE IN VOLTS24.0
SPECIAL FEATURESELECTRICAL OUTPUT RECONNECTABLE FOR 120VOLT,SINGLE PHASE,2WIRE120/240 VOLT,SINGLE PHASE,3WIRE;OR 120/208 VOLT,THREE PHASE,4WIRE.
FUNCTIONAL DESCRIPTIONTACTICAL SKID MOUNTED POWER SOURCE,CLASS 2B UTILITY,OPERATING ON DIESEL OR JP8 FUELS,USES STANDARD MILITARY OIL,LUBRICANTS AND COOLANTS.
RELATIONSHIP TO SIMILAR EQUIPMENTTHE 10 KW AMMPS GENERATOR WILL REPLACE THE 10 KW TACTICAL QUIET GENERATORS IN THE FIELD,PRESENTING A LIGHTER,MORE FUEL EFFICIENT SET WITH SMALL LOGISTICS FOOT PRINT.
TYPE/MODEL DESIGNATIONPU-827/G
Army MIL article
DieselAddict
1,903
Efland, NC
Some of the models use a PMA with an inverter instead of a brusheless alternator. This allows the engine to run a variable speeds based on load. More like the MEP831a.
Dewie38
189
Milford Ct
None of the AMMPS units have a PMA or Inverter
The 5, 10 and 15 kW's use a Cummins generator and the 30's and 60's use a Marathon generator.
DieselAddict
1,903
Efland, NC
Thats a bummer. The development info suggested the smaller units would be PMA/inverter based.
I didn't get to see inside the 10kw unit so I was still going on second hand info.
Daybreak
2 Star Admiral
760
Va
We had MEP-002 5kw
then we had MEP-802A 5kw
we now have MEP-1030 5kw
AMMPS MEP-1030 5KW Generator info mode =I 50/60Hz
NSN 6115-01-561-7329
5kW MEP-1030/1031 3 cylinder, Kubota D902-IV
Name
Value
MOUNTING TYPE
SKID
OVERALL LENGTH
45.000 INCHES NOMINAL
OVERALL HEIGHT
OVERALL WIDTH
III CURRENT TYPE
AC
FREQUENCY RATING
MEP-1030
810.000 POUNDS
AC WATTAGE RATING
5.0 KILOWATTS
24.0
SPECIAL FEATURES
ELECTRICAL OUTPUT RECONNECTABLE FOR 120 VOLT,SINGLE PHASE,2 WIRE 120/240 VOLT,SINGLE PHASE,3 WIRE;OR 120/208 VOLT,THREE PHASE,4 WIRE.
THE 5 KW AMMPS GENERATOR WILL REPLACE THE 5 KW TACTICAL QUIET GENERATORS IN THE FIELD,PRESENTING A LIGHTER,MORE FUEL EFFICIENT SET WITH SMALL LOGISTICS FOOT PRINT.
TECHNICAL MANUALS
PU-825/G
TM 9-6115-749-10
TM 9-6115-749-24&P
Jericho
69
Landaff NH
Sounds good, but let me say, Iv been off grid 23 years since I retired, I got 57 thousand hours out of a 22 kw Mitsubishi powered gen set, only changed a water pump. Pulled engine for a rebuild was in great shape still, probably didn't have to, was still running well. Run a tier 4, 33 kw John deere diesel as my secondary, Has 3000 hrs ,alresdy had to change the fuel control solenoid, $ 700.00 , only last 1.2 years. Deere starts well but smokes a white cloud large enough to hide A C-5 (aircraft) for 3 to 5 minuets on most winter starts . Picked up a 3 kw onan powered Mep 016 , really will easily push 5 kw , now that ive changed all the carb and fuel pump, fuel lies ect runs well , but don't think its going to rivial the mitsu
NEIOWA
124
NE IOWA
The money line in OP info "Environmental Protection Agency Tier IV Interim Compliance".
IE: the EPA runs the DOD when the wackos run the gov't.
dependable
187
Tisbury, Massachusetts
Tier 4 interim compliance is not necessarily that complicated. But that only gets you to 2012, I believe. It is the tier 4 full compliance after that where you see more annoying add ons like DEF or catalytic exhaust with burn cycle.
This speaking from my experience with small (30-60 HP) diesel machines I have in my business. I repowered a skid steer with a Mitsubishi S4S that was sold to me new and cheep because it past 2012 mark without being installed in a new machine. It is the last of the mechanically injected, no DEF or afterburn motors I'm ever likely to acquire new. My 2015 mini skid has a 37 HP Yanmar, and it has a catalytic exhaust with burn cycle. It has not been an issue so far, but ****, that is one complicated engine compartment, I do not look forward to working on it.
Daybreak
2 Star Admiral
760
Va
Howdy,
A lot of it comes down to the horsepower rating of the engine. Not every horsepower rating is under tier 4 compliance.
