What is max tire size stock
b652469
Fort Worth
I searched and can't seem to find the max stock tire size? I'm thinking of purchasing a rubber duck lift but...... Don't feel like installing it...
Thank for for the experienced advice!
Retiredwarhorses
4,072
Brentwood, Calif
You can't go larger than 38's without a body lift...once you hit 40's, stock up on pitman, idlers and front Ball joints.
that or upgrade all of it to Moog problem solvers.
Retiredwarhorses
4,072
Brentwood, Calif
Not over built...required and standard issue on new hmmwv's. The old Pittman and idlers are a weak point...there have been several versions over the years. Moog PS's are heavy duty.
b652469
Fort Worth
Well I bought (3) I guess I need to figure out which one is going to be the dedicated off-road rig the spend the time and monies to do it right. Thanks for the info!
