what is the difference between hmmwv wheels
crazzyrman
NJ
What are the differences between the 8, 12 & 24 bolt wheels?
I keep hearing people say the 8 bolt are bad & get rid of them, but no reasons why.
Are the lug nut patterns the same on all of them?
Are they the same or different widths?
Can the center bead lock/ run flat inserts from 1 type be used on another?
86m1028
17
Murphy TEXAS
Pretty much what datguyc said.
They are all the same bolt pattern (8 on 6.5) and width.
The 8 bolt wheels aren't as strong as the 12 bolts (more space between the bolts) means they are easier to bend.
The 8 bolt wheels were designed for the bias ply 36's & magnesium runflats.
The 12 & 24 bolts came about with radial 37's rubber runflats & heavier humvees
TNriverjet
24
Clifton, TN
I think part of the gripe with the older 8 bolt wheels is that most of them have the 36" bias tires. If I bought a truck with these wheels, I'd be scouring auctions and "for sale" listings for radial tires with the newer wheels. There also may be a hub/bolt pattern change in there somewhere too, so watch out for that.
1,174
The old 8 bolt rim is not rated for the higher pressure used on the radial tires.
fwiw, this has been discussed/covered in detail before.
1,174
So, there are 3 generation/versions of rims.
Humvee AO rims(8 bolt bias tires), Humvee AO1 rims(12 bolt radial), and Humvee AO2 rims(24 bolt radial)...
Retiredwarhorses
4,135
Brentwood, Calif
let me muddy the water even further...they are 2 versions of 12 bolt, early and late style, late style can be spotted by the
addition of a lone centering hole, they also have galvanized studs, use the red O-ring and 1 piece run flat.
the "early version of the 12bolt used No centering hole, used 2 piece rubber run flats and had a thicker O-ring.
now onto the 24 bolt rim...2 versions of those as well, even spaced studs and odd spaced studs.
24 bolt even spaced studs IIRC are 3850lbs while the odd spaced is 3450lbs....don't quote me, I don't have the book in front of me, but you get the point. They are for the new heavy armored trucks.
86humv
498
Texas
And...the early and late 12 bolt and even spaced 24 bolt wheel uses the same valve stem assembly.
Odd spaced 24 bolt uses a different valve stem.
