ColtRice17
- 0
- 0
- Tulsa, Oklahoma
I think this is a pressure regulator which should bleed off air but not as much as it is which totally drains the tanks.
http://lmgtfy.com/?q=+part+number+for+the+M923A1+blower+motorWhat is the part number for the M923A1 blower motor?
All of them I've ever seen cut off at 60 psi so I would assume they are all standard.Again, I don't got alot of air system experience, but, if it has to do with braking, I assume it will be standard across the board. From the description and operation I read, it is designed to figure out when there is a failure of an air system accessory and default/route pressure to the braking system so you can stop safely. Looks like magic to me!
I wonder how many NAPA counter guys are on Steel Soldiers?Ok thank you. Is there a part number to look for. Napa here is full of lazy people who wont look up a bolt without a part number.
