- 8,277
- 618
- 113
- Corpus Christi, TX
Had a lot of questions about stuff I was selling so here is a layout of a basic VIC-1 system. I put out signs showing what is what but in case it doesn't show up----
Battery -> CX ? cable -> MX-7777 Surge Supressor -> CX-13908 cable -> Mount MT1029 -> CX-4723 cable -> Amplifier AM-1780 (also known as a J-Box) -> CX-4723 cable -> Control Box C-2298 (also known as a C-Box) -> headphone/microphone set
The Mount MT1029 is made to hold a 12 series radio such as the RT-524 which makes an AN/VRC-46 radio set. By adding certain components you change the radio system such as adding additional mounts and radios or adding a listening only receiver set R-442 which makes and AN/VRC-47. Other than the Mount MT-1029, none of this is shown in the photo.
Various types of microphone and headsets can be used on the C-2298 box. There are integrated ones with the microphone mounted on the headset. You can also use a separate headset and microphone as shown. Or you can use a loudspeaker and microphone. A lot of choices here.
The amplifier AM-1780 has 3 hook up positions on the top and one on the bottom for the CX-4723. The CX-4723 from Mount MT-1029 must go into the plug in point marked J-801 on the amplifier.
I hope this helps folks visualize what they need.
