Truckoholic
- 13
- 0
- Colorado Springs, CO
Okay, so I have a couple options for getting a truck home. I own a logging truck that has a pintle hitch on the back, and therefore could easily use a tow bar to pull a 2.5 or 5 ton truck home that way with no problem as far as my trucks capability. Or I also have an equipment trailer with ramps that I could fairly easily haul a truck on, but getting the truck up onto the trailer if it is not running, is kind of a hassle although I have done it with other vehicles.
But I would prefer to use a tow bar, and just tow the truck behind my truck so I don't have to mess with pulling the truck up onto the trailer. But I am just curious as to what needs to be done to the vehicle to make it ready to be towed. I mean not the obvious, like the tires needing to be inflated and brakes and lights. I'm talking about the drivetrain. Are these trucks designed to where they can just be put into neutral and towed without removing the drive shafts? Or do the drive shafts really need to be removed to prevent damaging the transmission or something? And would it make a big difference between say an M813 with manual transmission, and an M923 with automatic?
And as far as the brakes go, I notice they seem to have gladhands on the front. Do all of them have these gladhands, and when you attach airlines with service and supply brake pressure, does it treat the MV as if it is a trailer and automatically release the spring brakes when you activate the supply pressure, or do you need to do something in the cab, or underneath for the brakes? My truck of course has airbrakes, and the connections at the back, and I can easily make up some air lines with gladhands on either end for that purpose.
I've got my eyes on some trucks going up for auction that are actually on my side of the country, and will be plenty easy enough for me to go recover myself with my own truck. I just want to have a good idea of what needs to be done to make them towable, or if the military pretty much designed them to be towable in their drivable configuration. I guess though, if I plan to tow them with a tow bar, I best be getting my hands on a tow bar before I bid on anything. ha ha So might just use the trailer anyway. We shall see.........
