What oil are you using in gensets
Steamynachos
Calgary Alberta
Hi guys I just got a nos Mep-026A and was wondering what oil do you guys use in yours for best performance. The tm calls for 30wt or 15-40. I don't want to blow her up on first try.
PeterD
Jaffrey, NH
I run 15W-40 in all my diesel engines (Rotella) year round. My generator, in the winter, is in my shop so it doesn't get all that cold, and in the summer around here in NH, it doesn't get all that hot either. (Of course another factor is that I'm not buying a bunch of different oil weights, too.)
ammodude
McAlester, Ok
[thumbzup] Another vote for 15w-40 Rotella, with two diesel trucks, hree diesel tractors and a MEP-003A (I need to get running) it is normally cheaper by the five gallon containers unless you find a good sale.
m139h2otruck
NH
For any diesel, I would use a good 15w-40 diesel oil. For gas engines, I use 10w-30 on the newer aluminum engines and non-det SAE 30 from Tractor Supply for the old iron flat head engines.
glcaines
2,593
Hiawassee, Georgia
Every type of oil listed in the previous posts is excellent oil. I don't think the particular brand is nearly as important as making sure it is good oil with the correct specs for the application. Good oil doesn't necessarily mean a higher price either.
BKubu
1,162
Gaithersburg, MD
I second this. I feel the brand is less important. I try to select a brand name that is on sale. I like Rotella, but I also use Mobil Delvac (another very good oil!), Pennzoil, Valvoline, Quaker State, and others. I often get my oil from NAPA and the 5 gallon pails they sell are sold with a NAPA label, but it is made by Valvoline (just ask them if you doubt this). Good stuff. As I said, select a good brand name oil and change your oil often. If anything, I believe more in selecting good brand name filters. I have used FRAM without any problems, but I prefer to use WIX (usually NAPA or Carquest brand).
To answer the original post, I concur with several of the other posts...I use 15W40 in my 5KW diesel genset.
