What oil for driveline?
midcounty
26
Preston, MD
I want to change all the fluids in my Deuce and need to know what to put in the drive line. What is a good commercially available gear lube for the Deuce driveline that will properly lube the bronze bushings found in these older units?
midcounty
26
Preston, MD
I need to use the search more and figure out how to search things out properly. I usually end up getting a load of unrelated threads that take forever to sift through. Thanks though, found the info I needed in the above listed threads.
1,179
Try using the Search function on the left side of the screen, under the list of who is on-line.
Select "Advanced Search"
Use 2 or three key words(play around with synonyms), and choose the correct forum to search in.
This should improve your search results.
To everyone please keep in mind, Accurate, Descriptive Titles are important, when posting threads. We need to look at the titles found in our search results, to best choose which threads to read, to find what we are searching for.
1,132
Westy has been practicing his search kung fu skills.
Search on grasshopper!
gimpyrobb
dumpsterlandingfromorbit!
27,786
755
Cincy Ohio
The best bet is to go to the forum of the vehicle you are looking for answers on, and search there. If you search the whole site, you get less specific results.
