What pre-filter before electric fuel pump
CPAPPY
Xenia , Ohio
Need help finding a pre-filter before the electric fuel pump I am installing on my M1028. I have looked all over . Napa sells one filter down to a 140 mic. Is that good enough. Just wondering what others are using.
kapnklug
spencer,ny
The built-in prefilter on my Walbro FRB-22 pump is rated at 300mic, so the 140mic one from NAPA should be good. Problem with mine is the surface area is too small, would need to be cleaned less if it was bigger
xenocath
searching.............
193
Glen allen, VA
i am seeking info on a cleanable prefilter for an electric fuel pump install what are folks installing before their elec pumps?
xenocath
193
Glen allen, VA
i am seeking a cleanable element model not plastic if possible and see thru.
I want more of a "you don't need a parts store replacement" just clean it out and keep rolling type deal.i did a search and came up short on a usable model meeting those criteria and since this here thread was already active i would ask here and make searching easier on the next guy.
