What PTO Pump for Snow Plow Hydraulics?
Senderofan
152
33
South Dakota
Hey Brothers:
Looking for advice on PTO pumps / Hydraulic reservoirs to run a DOT style snow plow? I'm looking at purchasing a M923A2 and need to figure out components to install a snow plow that turns right / left and raise and lower. I've tried to do a search here.....but haven't been able to get a solid answer per my search. The truck I'm looking at has the 8.3 liter.
Thank you Immensely !!!!
Senderofan
Glenngineer
The transmission will not drive the pto properly unless it is in neutral so you would need an engine driven pump or an electric pump system for a plow.You would get some flow out of a pto driven pump but it would depend on what gear you are in and how fast you are going ,so it may not be adequate or predictable.
Jbulach
2,184
Sunman Indiana
“The transmission will not drive the pto properly unless it is in neutral” , or in gear with the truck moving.
Depending on your application will determine weather it will work for you. While not great for commercial parking lot clearing, the transmission pto will work fine for hwy, private roads and long driveways.
snowtrac nome
139
western alaska
the best way to do it is off a crankshaft drive system, if you are only going to run a plow you might get away with a pump run off the accessory drive.
Senderofan
152
33
South Dakota
Thanks for the responses. I need to raise / lower infrequently. Also turn left or right when completing the second half of my run. Will be plowing 1 1/2 miles of road....half gravel and half blacktop. So I don’t need anything quick or for frequent maneuvers.
Jbulach
2,184
Sunman Indiana
I think Tobys had a direct mount pto and pump for sale, but he hasn’t been on board in quite some time. If you cant get him through PM, I may have his number. Ive been meaning to get ahold of him anyway to check and see if he’s ok.
davidb56
1,237
Bonners Ferry Idaho
I put a engine driven pump on my F350 / 460ci truck. I installed a 4 way joy stick to operate the rams. the raise/lower ram is a double acting, but it raises and lowers a arm and chain, so there is no down pressure. the angle rams are single acting . I paid 650$ for the pump with the clutch, 100$ for the tank, about 60$ for the hoses, 300$ for the joy stick control valve. all from Surplus Center.
Neophyte
If speed is not of the essence, a 24v hydraulic power pack.....an electronic manifold .....and a joystick should do the trick. My M925 has hydraulics I used to power the angle cylinders.....but I added a 24v hydraulic power pack (single acting) for the lift cylinder. I used the plow for a 3/4 mile long gravel driveway.
country
390
Feasterville, Pennsylvania
We have shallow PTO set for M925A2 transmissions with close coupled hydraulic pumps - good used take off for $1200
also have plow mounts with hydraulic cylinders- already set to mount to M939 trucks for $900 each
Email for more info if you like
dave
Senderofan
152
33
South Dakota
dave
Thanks Dave....We are now in email contact.
Wayne
