What size shocks for lifted M1008
ssgtwright-usmc
Hawaii
The M1008 that I own had had a four inch body lift added to it before I bought the vehicle.
What size shocks should I be looking for? Looks like my M1008 still has the original springs and Im guessing the springs by themselfs gives the truck a 4 inch lift, then the 4 inch body lift should give me a total of 8 inches.
So, what size shocks should I be looking for and also, who makes the best brand for the money????
AJMBLAZER
Paducah, KY
I'm confused...you say it has a 4" BODY LIFT, stock springs, and the springs have 4" of lift?
We need pictures of some of your body mounts and also the springs.
Are the front springs flat or slightly down at the ends? Is there a block between the rear axle and the springs?
Sounds to me like you have a stock suspension and maybe a body lift. No one makes a 4" body lift as anything beyond 3" is considered pretty universally to be unsafe so I'd bet if you have one it's a 3" or someone rednecked up a 4" body lift.
Best shocks for the money are Bilsteins. Best shocks for us poor people with trucks are Rough Country Nitro 9000's.
ssgtwright-usmc
Hawaii
Original springs, has a four inch block in back and many drop brackets under the frame lowering the swing bar, transmission brackets and ect.
It may be 3 inches but when I measured the blockes in back it measured 4"
AJMBLAZER
Paducah, KY
We need pictures of all of this stuff.
Did you buy it from the government or a civilian?
Just so you know a body lift wouldn't affect the shocks at all. They're mounted to the frame and the axles so the body moving away wouldn't affect them other than maybe more room to access the frame mounts.
AJMBLAZER
Paducah, KY
Get pictures and we can give you a better idea of what is going on with the suspension and body lift.
Big tires shouldn't kill the steering system. If it's bad it was already going.
ultim8gamr
Napa Valley, CA
this sounds like a suspension lift with blocks in the rear.
a body lift would not require the transmission to be lowered or the transfercase to be clocked down. body lift is all above the frame so none of these driveline angles change. sway bar oly has to be dropped if the distance between the axle and framerails has increased, indicating a suspension lift.
as for what kind of shocks, i ran the rancho shocks mentioned above for my 4" lift
AJMBLAZER
Paducah, KY
Re: RE: What size shocks for lifted M1008
Rough Country? Nobody mentioned Rancho's overpriced rebadged junk.
ssgtwright-usmc
Hawaii
RE: Re: RE: What size shocks for lifted M1008
That is what it is, a suspension lift with rear blocks.
The blocks are 4" so Im trying to order the right size shocks that will fit the truck.
puppy
Rives, TN
Rough Country Part #'s for 4" lift
Hydro:
F - 8106
R - 8112
Nitro:
F - 9106
R - 9112
Note: These rear shocks(or any others) may reguire you to relocate the lower rear shock mounts due to the increased diameter of the aftermarket shock tubes.
AJMBLAZER
Paducah, KY
Shouldn't on one of these trucks. The factory shocks are fairly big as it was. I've never had to at least.
ssgtwright-usmc
Hawaii
Think I will go with tough country 9000 series.
4 Shocks, steering stabilizer and 5 boots for $191.25 but that does not include shipping.
This is from their website directly!
Thanks again
AJMBLAZER
Paducah, KY
That's not the greatest price.
Try JCWhitney for the Rough Country 9000 series. Sometimes they have sales on shocks and othertimes they just have a % off and it knocks down the price a good bit.
If you're paying for the shock boots just forget it. Waste of money. I don't even run them.
ssgtwright-usmc
Hawaii
I was told that boots can do more harm then good esp... where humidity is bad.
They tend to collect dust and crud which collects on the piston shaft and will cause internal damage.
Croatan_Kid
New Bern, NC
Shocks are the only things I will buy from 4 Wheel Parts, they have some good deals. You can get 4 shocks and a stabilizer shipped to you for about $160.
AJMBLAZER
Paducah, KY
Re: RE: Re: RE: What size shocks for lifted M1008
You heard right. I haven't run shock boots on any of my vehicles in years unless they came with the metal ones. Even been tempted to cut those off.
CCATLETT1984
Saint Clair Shores, MI
I had that issue on my trucks rear axle. Was a 6" lift block though so more rotation of the axle. but i had to install the hydro (came with kit) shocks upside-down to get them to fit.
AJMBLAZER
Paducah, KY
RE: Re: RE: Re: RE: What size shocks for lifted M1008
Huh.
Last 6" I did was all spring and we never had to dink with it other than put them on. Wasn't a Superlift lift though.
