rmgill
- 14
- 38
- Decatur, Ga
On the Deuce, what are the best sized snatchblocks for single and double line pulls using the front winch?
the smaller snatch blocks sometimes talk about various sizes all the bigger ones seem to have one size. I like that warn block, but it says 7/16 cable. isn't the M35 winch 1/2 cable?cranetruck said:Aren't snatch blocks rated/used according to the size of wire rope that can be properly fitted on the sheave? In other words, use the snatch block that fits your size wire rope.
this is right. so if you have a 13000lb truck and it is stuck bad it could need 39,000lb of pull to get it out. I think the military says figure a 3:1 ratio on rolling vehicle weight to stuck vehicle weight. This isn't the case all the time, but it is a rule of thumb. I think the winches are meant to be used in conjunction with the wheels driving as an assist tool.rmgill said:if you run the pulled line back to the pulling truck you're only looking at the load of the pulled object being the load on the block. I suspect that if you ran your line from winch to block on load to block on truck to load, that you'd be looking at double the line pull on the block on the load.
The deuce winch is rated at 10,000 lbs not 10 tons. It's ton rating is 5 tons and I think the snatch block for the deuce front winch is 10 ton or 20,000 lbs. That means the 10 ton snatch block is just right. math is toughrizzo said:the snatch block for a M543A2 is a 8 inch single sheave, 5/8 rope, 10ton working load.
I don't understand how they can use that on a winch rated for 10ton. Wouldn't they need a block that rates at 20ton? twice what the winch will do. 20ton is whats gonna be on the block hook. and 10 ton on each line. Anyone know??? Same with the rear winch. They have a block that weighs @80lbs but only rated at 15ton. the winch is 22.5 ton.
Ryan. If you find a block at a good price let me know. I would be interested in getting one too.
the M543A2 is not a deuce.ida34 said:The deuce winch is rated at 10,000 lbs not 10 tons. It's ton rating is 5 tons and I think the snatch block for the deuce front winch is 10 ton or 20,000 lbs. That means the 10 ton snatch block is just right. math is toughrizzo said:the snatch block for a M543A2 is a 8 inch single sheave, 5/8 rope, 10ton working load.
I think that is a great price too. Only 5 ton though????mangus580 said:This is the one I got I I think its the one that came with the deuce.
http://www.galleria-e.com/cgi-bin/Colemans.storefront/en/product/190601
are you talking about the winch drum? the cable and the winch only get half or whatever the winch pull is. On a 10k winch each cable leg(one going too the block and one coming from the block) get 10k. When you hook the cable coming back from the block to your truck or another anchor point that has to withstand the 10k that is on the cable.Elwenil said:Also you need to remember that while the drum is only carrying half the load, the cable gets it all as well as any mounting point that the snatch block is hooked to. There are several good books on recovery as well as a few military manuals that can help you out and keep you out of trouble.
