What size speedometer gear do I need
Skinny
487
Portsmouth, NH
I can't speak on the Cuck Vee's behalf but all mechanically driven New Process cases will have a color coded gear. You can also count the teeth if the gear has any left. Pull the drive mechanism out and check the color. Any 4wd shop should be able to source one for you.
