Csm Davis
- 381
- 83
- Hattiesburg, Mississippi
Use 2!
Sent from my SM-G900V using Tapatalk
![](http://uploads.tapatalk-cdn.com/20161101/cb1ea3cbe0f22e6cae7abca62f5f17b6.jpg)
Naw going towards Ga. So not doodoo from rally.That is one big septic tank. It must be full of rally doodoo to be that heavy.
Just giant 6 cylinder diesel I believe.HOLY SMOKES!! That is one DENSE object! to require TWO!! Wonder what it looks like and what it's made of under the plastic wrap!
If you could see the other side there is every kind of officer you can name and a few I have never seen before.Lets go find a DOT officer that likes to use his scales. It looks like a tire guys worst nightmare when all those tires wear out.
Sent from my SM-G860P using Tapatalk
That trailer was designed by an idiot (prob a retired Transportation Corps Officer) after consulting with a group of morons (civilians that had never driven a truck before). It was over designed and was a nightmare from the word go. To change the inner tires you had to rotate the stubby axles. I was in a HETT unit for a while and most of us agreed that they were crap designed to keep the parts manufacturers in business for the next 20 years.That trailer has 8 tires and wheels for every "axle" not sure what you would call that setup because they don't appear to have body axles...
Typicaly referred to as a Dual Lane or Two Lane Transporter.That trailer has 8 tires and wheels for every "axle" not sure what you would call that setup because they don't appear to have body axles...
