signsup
- 89
- 18
- Atlanta, GA
Raining cats and dogs this morning, so can't go out and take pick, but will later of turret ring with the rubber seal and the rubber two piece bushings that I have removed to install a solid steel military issued cover hatch plate. eBay seller represented it would be correct for Humvee, and, you guessed it, only four of the 16 bolt holes line up. Data plate on cover says:
19207-12600087
MFR-75Q65 ( this is Oshcosh per Google) not a good sign
6222530000000019103
19207-12604893-025
When I Google the info, the mfg comes up as Oshcosh, so I know it wasn't made exclusively for a Humvee, but rather than redrill 12 holes through this hardened steel plate, I'd be intersted to trying to swap or find a correct plate. One clude as to what I need for my M1151 ECV slant back top is that two of the 16 holes are only about 3" apart from each other, the rest are evenly spaced out. The plate I have fits the approx 45" hole in the top.
Any direction appreciated. Here is a few pics from the Ebay listing of the cover plate I acquired.
19207-12600087
6222530000000019103
19207-12604893-025
