what type of suspention is under this truck
deuce_09
san antonio/TX.
how is this guy running that sized tires and still have tandems..
is it air bags,bigger leafs and arms on a stock setup,4 sets of leaf springs,or some kind of custom setup
Unforgiven
Las Vegas, NV
Chop the control arms & weld an extension into them. Put two extra-long leafs into the bottom of the leaf packs. That's the only way I've seen to do it (unless you know where to find extra-long control arms that would fit).
Notice the guy also chopped the bed to 9' to make room for a bigger radiator. He probably swapped engines to turn those larger wheels & needed the extra cooling capacity.
Greeniron2010
Banned
25
in
That truck pictured looks like a 818. But instead of 5th wheel they put a deuce bed shortened on it and hemtt wheels, with 1600s. I bet rest of truck is stock.
Also that looks like a stock spare tire carrier not a bigger radiator
hklvette
Christiansburg, VA
Dunno about the carrier, but agreed with it starting life as a five-ton. Notice the lack of holes in the side engine cover for an intake.
deuce_09
san antonio/TX.
o so those tire carriers are only on the 5 tons?
im tryin to find one..
and i was wanting to know because i have some 1400-20 micheline x tires but they are like 52" tall. if they'll fit the stock setup on a deuce, thats great but it dont look like it
ida34
33
Dexter, MI
I will pile on. It is a five ton M818. You can tell by the battery boxes, long fenders, spare tire mounting, Wheels etc. :deadhorse:
The carrier is M818 specific. The cargo truck M800 series have the tire mounted in the bed at the front. The M900 series cargo Five ton has space in front of the bed and mounts the tire in a similar fashion but on the driver's side. It also has a small boom for raising and lowering the tire. Hope this helps.
hairba11
st. louis (high ridge)
Thanks for the info. How the HECK do you lift one of those giant tires up there if you have a flat? Or even a stock tire?
Nevermind ... I just read about the boom.
well when the stock tire is an 1100-20, and you have a two man crew...
lean it against the space between the rear axles, heave it on top of the duals, climb up onto the truck, stand the tire up, and roll it to the carrier, then give it a little wiggly-jiggly (technical term) to get it up into the carrier. the diagonal braces hold the tire upright, while you get the bolt lined up with the outside support, tighten the nut to clamp the outside edge to the tire.
not that i've had to do that more than once before looking for a hoist.
Bob H
160
1400-20's are 49" tall 1600's are 53" tall
The stock deuce rear axles are 48" apart, so obviously you can not put anything bigger than the 46" 395's on the stock deuce tandum setup.
A few posts above Unforgiven - explained how you can modify the deuce rears to fit the big tires, although he did not explain that they will hit the bed & front fenders without a lift.
saddamsnightmare
80
Abilene, Texas
MAy 22, 2010.
Goodyear G177's M+S 1100R20's will go on the standard deuce, and they are about 43" OD.
Anything bigger and you probably need a five ton or better yet an HEMTT.....[thumbzup]
I worry somewhat about the liability inherent in altering a forged dogbone link to a different length, when you do that you are adding many more variables into the life cycle calculations..... and if something fails,Ouch!!!
