what would cause cold advance sensor to keep failing..
Warthog
231
OKC, OK
Need more info. How is it failing?
Does it work for a while and then quit?
Not working at all?
Does it ever work properly?
1,176
Failing off, failing on, failing to operate at all?
84cucv1ton
New Jersey
OK sorry.. i put a few old ones in.. they keep failing. like to make sure all is ok before i put the new one in. 1 worked for a bit then failed thanks
Warthog
231
OKC, OK
1,176
If your solenoid has an internal short, it could burn out the sensor, maybe.
Warthog
231
OKC, OK
The circuit that supplies 12v to the temp switch is hot as long as the key is on. It is circuit #39 in the diagrams.
The only load on the switch is the Fast Idle solenoid on the out side of the IP and the Cold Advance Control inside the IP.
If either one of these shorted in the could cause the switch to fail.
Or it could just be a bad batch of switches. Where did you buy the replacements?
Do you have a good multimeter that you can check resistance and amperage on the switch?
Ken_86gt
Williamsburg VA
That part should be very reliable. I suppose a short as mentioned would be the likely reason for failure- an electrical overload. How did you test to determine that it is failed? It could just be a loose wire/bad connection making you think that it is failed.
84cucv1ton
New Jersey
I didn't test. I have some spare motors. I pulled them out of their. They would work for one or two startups that was it. Third or fourth time I would start truck it would not idle up.
Any idea what the the amperage should be? Thanks
richingalveston
120
galveston/Texas
check and ohm your wires
being that the sensor ads resistance when it gets hot, you may already have to much resistance due to corosion in the wires itself. Test the loop from the controler to the sensor and back to the controler. (not sure where it is but i belive this sensor comes from the glow plug controler)
someone here can correct me on the ends to test from.
If your wiring (being it is old) is breaking down, the wires can add enough resistance to cause the sensor loop to always be on.
I am not sure where the circuit originates and which is the return circuit. but if you test the loop, then bypass sensor and test loop again. the difference in the two readings should be the actual resistance in the wires themself. a loop this short with good wires should have almost no resistance.
Old wires can cause many problems when devices use resistance in the circuit to opperate.
also if your wires are grounding out due to bad insulation this will create similar issues.
the sensor itself may be going bad fast because it is getting grounded out burning the tiny wires on the sensor which probably act as fuses.
