What wrench size is the bolts that hold drive shaft to axle on M1009?
armytruck63
10
Redlands, CA
I am 99% sure it is also 7/16" on the M1009 (been a while since I pulled my shaft). Bring a rag to jam in the transfer case output hole to prevent a big mess.
K9Vic
Fort Worth, TX
It is a 7/16 or 11mm, both are the technically same size (well too slight of a difference to matter). Do not bring a rachet wrench as it will likely not fit, does not clear the inside clamp.
Warthog
232
OKC, OK
Looking at the TM 9-2320-289-20p parts manual, the front drive shaft shows up as Item #13 - MS90728-86 and the rear shaft shows item #6 14018700
Looking up the parts on www.wbparts.com
So with all that said, the size is 7/16"
