whats the correct pop off psi on injectors
65
Danville pa
hey all I am wondering what is the coorect pop off psi on the deuce 2 hole injectors? I seen in the 5 ton troubleshooting manual that the injectors pop at 2750... I am wondering if this is the same for the deuce? I have a good set of injectors from a deuce, and they all chatter and break clean, just wondering what psi they should break at?
Any help would be greatly appreciated
thanks jon
tmbrwolf
Manhattan, Kansas
According to the multifuel engine repair manual TM 9-2815-210-34-2-2 the opening pressure for a new nozzle should be 3050-3150 PSI with no more than 300 PSI difference between any two nozzles in a complete set, doesn't make a differance one hole or two hole.
gringeltaube
Staff Member
2,389
Montevideo/Uruguay
->Resources-> Technical Manuals->2nd page, #7->download "LDS465-1 Troubleshooting Manual", ->page27: how to check & adjust injector nozzle (two hole) opening pressure = 2800-2850psi
G.
65
Danville pa
Thanks guys, I seen where this says 2850 psi... is this for the lds version or is this a universal pop off for both 5 tons and the deuce engines? my injectors are not new, so i cant use the factory settings of 3100 psi We are going to test stand check them, and I wanted to get a spec before starting.
thanks again
