BTC70
- 3
- 0
- Jacksonville, FL
I'm in the process of having my M1028 restored and am looking for input on wheels. I want to run 34"-35" tires and I want to keep the plain black steel stock wheel look. It seems that these 2 desires are incompatible. Therefore, I need to decide on whether to stick with stock wheels and deal with the narrow width (which means running smaller tires than I want or putting tires on them that are supposed to be on wider wheels) or buying new wheels.
Option 1) The wheels that came on my M1028 are a mixed set (all 16" and appear to be the same size, but slightly different designs - 1 even has a Chrysler logo stamped into it). These would have to be sandblasted and repainted.
Option 2) I also have a set of 3/4 ton wheels off a 1985 K20, which I would assume are the same wheels as our trucks came with. These would also have to be sandblasted and repainted.
Then there's new wheels.
Option 3) $107 each. I came across The wheel Vintiques Series 82 (82-680804) wheels (16"x8", 4" backspacing, -12mm offset). This option would look the same, but upgrade the width to what I want. However, I'm hesitant to buy them because I have been unable to find ANY reliable info on load capacity - even after calling the manufacturer (which is scary).
Option 4) $90 each. U.S. Wheel Series 044 Stealth Crawler. Satin Black steel wheels similar to the old "revolver" style wheels. (16"x8", 4.5" backspacing, +13mm offset, 5.15" center bore, 3,000 lb. load capacity).
I WANT option 3, but my head says not to buy them without knowing the specs.
