Wheel bearing removal - Rear Inner
Amxhunter
Mobile, Alabama
Looked through a hunnert threads :)
Looked through the TM :(
The inner wheel bearing needs to come off so i can replace the seal.
The TM says to use puller, dosen't say which one or p/n.
How do i get this thing off ? I have a nice 3 jaw gear puller but it's no where deep enough to reach the inner bearing.
kennys@wi.rr.com
23
Waukesha, WI
It shouldn't be on all that tight. Just did mine and it slid off after some gentle coaxing. But nothing much should hold it on at all. Try tapping the back of the seal with a hammer, seals no good anyway.
Amxhunter
Mobile, Alabama
Did the seal tap trick, just suceded in denting the seal :(
Link no help and Bjorns pictures are gone.
Bearing doesn't look like it got hot , but I got grease (not dope) all under the bed and on the tailgate.
I'm beginning to get that sinking feeling.
WillWagner
3,164
Monrovia, Ca.
Get a heel bar and pop it off with that. It will just slide right off. Maybe someone used loctite on it?
ctmustang
Thomasville-N.C.
I actually was doing bearings today and about 4 of 6 inners needed help. I took a thin screwdriver and a small hammer at the back of the bearing and tapped it down between the bearing and the spindle and from there it worked off fine. smear a little grease in front of bearing to help it slide off. Also had to tap the new ones on which is fine because you dont want them loose on the spindle.
CT:mrgreen:
