Wheel Bearing?
motormayhem
Tucson, AZ
Ok well while I had the front end up to slime a tire I noticed there is a small amount of play in the side to side motion of the tire. I have had no other symptoms of a bad wheel bearing and the lug nuts were not loose. Does this sound like the early signs of a wheel bearing on it's way out? What do I need to buy and what do I tell the parts store it's for, an '84 blazer or a k30 or what? Also how difficult is this to do and how long will it take.
Thanks,
Miles
Westech
CPL
6,104
212
cow farts, Wisconsin
ok first of all you have 1/2 ton axles in the blazer so you want to stick with Blazer/ 1/2 ton PU parts so the 1 ton is out. Second make sure you have no front end parts that are worn. A loose tie rod and a ball joint will do the same. If there all tight just take the hub apart and see what you have. 99% of the time all you need to do is clean and repack the bearings and reset them and your good to roll. I only have seen a hand full of burned up bearings in the 10 bolts.. but it has happened. First step.. take it apart and see what you have to deal with.
