Wheel Bearings??
hardtime
Bailey, Co.
Ok checked the site for any posts on detailed wheel bearings info with no luck. Are the rears of the 814 oil lubed bearings and the fronts greased? In my years working on late model heavyhaul trucks in northern AK. the rear bearings get lubed with the diff. oil and some of the earlier trucks got grease on the front axle bearings, same for the 1-ton fords I own.
Where do I find the bearing nut sizes so I can order the right sockets and what about wheel seals, is this a special seal or can I go to napa?
Any and all advice on this job is greatly appreciated.
area52
San Bernardino CA
Here is what I have found:
Front and rear are the same - both are greased
outer seal is 7413447 inner is 7979349
front and rear bearings are same. inner and outer races are civy # 592 or 592A
inner bearing is 593 and outer is 596.
spindle nuts -
4-3/8" 8 sided, and a 4-7/8" 8 sided. You can find them online, they are made by OTC. Usually cost between $25-$30 each
same for front and rear
P.S. I found all this by searching for seals,bearing and nut sizes in the 5 ton forum.
73m819
319
gainesville, ga.
the touque or setting the bearing is 50# while rotating the hub, then back off 1/4 to 1/3 of a turn
