Wheel/Spindle bearing replacement
CUCV420
RENO, NV
Hey, I need to replace pretty much everything in my u-joint assembly.I can get everything for wholesale, but I am trying to get a complete parts list and I need some help making sure I'll have everything I need. I need to replace the wheel bearings on both front wheels on my 1986 CUCV M1009 I also need to replace the U-joints, all the ball joints, and naturally all the seals since i'm there. Also, I some slack from the axle as well and i'm assuming its some sort of spindle bearing somewhere that needs replacement.
Anyone who has done this job before, please help me get the necessary parts for the job.
kevin-m1008
colton, or
There should be a tm on this site you can look at to get a complete parts list.
Is the differential R&P good and bearings? if not maybe cheaper to find a whole front end.
You may as well check the spindle bearings while you are in there.
