Wheel weight? - 14.00R20 AT-2A + combat wheel
Bandit02
Blind Bay, BC
Does anyone have an idea what a Goodyear 14.00R20 AT-2A with a combat wheel installed weighs?!
I got a smokin' deal on 7 of them and have to haul them all in the back of my short box Ram 2500 lol for about 350 miles. I think if I stack them just right it can wing this. My truck's payload maxes out at 2550 lbs just wanted to be sure I can do this. I also have to put all 11 of the G177's in the back to haul them up as well for this trade.
Thanks!
MtnSnow
14
NSL, UT
a 1400 x20 tire and wheel will weigh in right about 400 pounds depending on if and which type of bead lock/run flat is installed.
HanksDeuce
242
Prairieville, LA
The Goodyear website below states just the 1 tire weighs 263 lbs.
http://www.goodyear.com/cfmx/web/gov/pdf/military_tire_brochure.pdf
Searching ebay for "2 piece combat wheel" comes up with an auction that states 152 lbs for each rim (in original container). No clue what that means.
263 + 152 = 415 lbs (with packaging). Let's say 410 lbs to be safe. 7 x 410 = 2870 lbs. 320 lbs over your limit. Pulling them on a trailer might be a better option. Utility trailer with a drop gate.
Coffey1
497
Gray Court SC
Trailer is the best option.
Trying to stack those in a truck would be a killer unless he has wrecker to stack em.
gottaluvit
You will never be able to fit seven in a short bed, even standing upright. I hauled eight in a 16' trailer and couldn't fit one more without stacking or standing them straight up. The first two layed flat and I leaned the others all against them and barely got the ramp gate closed. If you stacked them in the truck, being so heavy, if the load shifted any, it would be near impossible to correct without some form of lifting device.
