Third From Texas
- 6,492
- 113
- Corpus Christi Texas
I've had this issue since I got the A1R.
All of my LMTVs were converted to dual battey as soon as they came into my possession. And I pretty religiously throw my battery disconnect every night. I've had no 12v vampiric drain issues as a result. If I forget and leave the batteries hot, after 3-4 nights if the truck isn't driven the 12v side will slowly slip into the low side (failing to start the truck and certainly causing some damage ton the battery).
But if I leave forget to throw the disconnect and it RAINS, the 12v battery will crater over night. I've never been able to identify what is getting wet and causing the 12v drain. I'm at a loss for how to locate the short (spraying water around on various locations has never resulted in any help). It has to be something exposed outside the cab. There's no water in the battery compartment, the NATO port, the battery diconnect box. I suspect the polarity protection as I park nose down on the driveway and water from the habitat lands between cab/hab. The only other culprit might be the starter (but I don't see any signs of water and being 24v I would expect to see both batteries discharging if so.) Where ever the short is it's isolated to the 12v system. It could very well be related to the typical 12v vampiric drain these trucks often suffer from.
Thoughts on how I might trace this?
*it rained for the first time in months here and of course I had left the batteries hot when I checked something the day before, so now I have killed a good 6TL battery (was down to 4v).
