Where can I buy king pin studs?
Thompsona3
Shelby twp MI
I was wondering if anyone knows where I can get kingpin studs that are 1/2 in 20 tpi and 5 in long. I am useing regular hex bolts right now but want to get ones with the right size center so there isn't play in the kingpin.
sweetk30
horseheads,ny 14845
what ?
your question didn't make sense . not enough info .
the studs for the upper cap/steering arm ? on a dana 60 front .
if so there is lots of 4x4 parts shops with them .
or are we working on a blazer with 1/2 on axles ?
Chaski
56
Burney/CA
Steering arm studs can be had from ARP... Just not 5" long ones. You can get a 2 foot long grade 8 stud from McMaster-Carr and cut your own. Part number 90322A166. They also sell tapered nuts, part number 4991T965.
Personally I'd never run a riser block under a steering arm, which must be what you are doing to need 5" studs. You can get the ARP studs from Reid Racing, but they are only 3.4" long
1,807
I have run the 60 stsering arm block before. I don't care for the design. Torsional stress on those long studs must be massive.
sweetk30
horseheads,ny 14845
o.k. as posted ord has good stuff.
I have aslo run a lift block / spacer for the dana 60 stuff IT SUCKED !!!!! only in my truck a few weeks then out it come .
best way is 3-4" lift but still stock steering = drop pitman arm for steering box .
perfect world 4" or more = crossover steering . ord has nice kits . BEEFY stuff. requires 2wd steering box swap . easy to do .
I would not run threaded rod even grade 8 for this application . lot of moving forces at play here .
if you MUST run a spacer / steering block get a ord one . 10x better design over those cast un even sloppy off the shelf units . those tend to loose tension on the king pin spring and create death whobble problems .
1,807
Death wobble was a huge issue for mine. Even with the sprung steering stabilizer it was hard to control. When the block was abandoned, the death wobble left with it.
