Where can I locate one of these trailer hubs?
Lonesome715
24
Columbus, GA
I know a lot of thee trailers are getting cut up and used as beds on bobbed deuces. So I am hoping someone has the hubs lefts over. I only need on side and if the bearings are still good I will take them as well. I also need the hub nuts and washers from both sides. I am trying to get this done for someone so this is a time sensitive issue. If you have the parts I need please let me know what you want plus the cost of shipping.
The trailer is a M116A8 but I think it is the same as a M101A1.
NDT
6,304
Camp Wood/LC, TX
These are Dexter axle parts available from trailer supply houses. Place here had the bearings in a bushel basket.
Lonesome715
24
Columbus, GA
Fleet pride here has the bearings and can get me the hub, but the cost is way too high. That is why I am hoping to find a good used hub. Even if I have to buy the internals new.
papercu
31
Baxley, Ga.
I think most of the trailers bodies being used for the bobbed trucks are M105?
Seems as if Kenny was swapping out axles on some trailers he just bought but he and a lot of the other folks are on the road going to or at the rally. Wayne
Lonesome715
24
Columbus, GA
It figures. I wish I had asked this question a couple of weeks ago. Then some one going to the Rally could have brought one down. I have seen a few bobbed deuces with this type of trailer body.
ida34
33
Dexter, MI
You want the hub for an M101A3 or A2. The A1 and straight M101 had a M37 bolt pattern.
96XJ9705
SoCal
Yeah, it looks like a replacement is needed. I'm not sure what I'm going to do with the old one. Best I can figure it is a 5000lb axle and I don't know of many needs for a 5000lb axle with 43.5" spring perches.
96XJ9705
SoCal
25.00 for hubs, brakes, axle, and ubolts too much? I'm thinking I'll keep the shocks and bump stops for the new axle.
