- 5,967
- 4,189
- 113
That's the one i called about. I didn't get the info on what the output current capability at the other voltages, but i do know that if you wire the head for split 120/240v single phase output, the Kw capacity is about 1/3 of the rated output.
Unless I misunderstand something, the output should be 2/3 of the rated output.That's the one i called about. I didn't get the info on what the output current capability at the other voltages, but i do know that if you wire the head for split 120/240v single phase output, the Kw capacity is about 1/3 of the rated output.
