Very clean install, sweet.you could install a few accessory buss bars. Tie in at main ground and at same point slave cable is connected to the battery.
Use the MX7777 suppressor for all your supplies, it's wired to the battery and provides the protection you need for all your accessories. Problem may be finding the cables, but they are out there.Ok, I see that. It appears to have waterproof connectors on it.
Where would one go to power a more significant load, such as a tactical radio? Is there a common lug somewhere where all of those sorts of circuits are intended to be connected?
-Chuck
Via the MX7777, perhaps I wasn't clear on that point in the post above......
Where do the tactical radio loads get connected?
.....Chuck
I understood that, but I am pretty sure my deuce doesn't have an MX7777 installed... unless they were a standard item, and then I would have to wonder why they aren't shown in the -34 manual.Via the MX7777, perhaps I wasn't clear on that point in the post above.
