where to get parts for injector pumps
joshua180422
Hawley PA
I am trying to get a bolt for my injector pump. I was just wondering where I good purchase one, actually probably a couple just to make sure I don't have this problem again. If any one could point me in the right direction I would really appreciate it. Here is a picture of the bolt I am looking for.
1,171
Isn't that the bolt that the TM says is matched to the IP, and to never interchange them?
derby
S.E. MI.
Doghead, I think you are right. I think that is the fuel metering screw? You may be replacing the Hydraulic Head. Was it leaking?
1,171
I think GR told me he swapped/replaced one successfully, once.
gimpyrobb
dumpsterlandingfromorbit!
27,785
748
Cincy Ohio
Mine was cracked. I had to try 5 different plugs before I found one that didn't leak. You will be better off swapping hydr. heads.
If anyone has bad IPs or HH, I would gladly purchase them from you. These types of parts are needed once in a while.
gimpyrobb
27,785
748
Cincy Ohio
Thats the plug in the side of the hyd head. You might need to send more than one to find one that works.
