Where to get replacement hydraulic hoses?
Nitetrain
Arlington, VA
I have a SEE and need to get some replacement hydraulic hoses. Does anyone know the fitting sizes I should order and where the best place is to order them from. Thanks, and sorry if this is a repeat thread. I could not find the answer when I searched.
I would like to start by replacing some of the hoses on the front loader. I have added a close up of the fitting. I am not sure how to read it.
silverstate55
Unemployable
868
UT
Looks like a tapered (AN-style) swivel fitting. Find a hydraulic hose shop and have them make new ones based on the old ones...disconnect old hose, clean it up, take it in for same-same measurement & fabrication.
I have had the best luck finding your nearest Parker hose outlet and trying that. Otherwise look for a hydraulic hose repair shop.
ETA: Make sure that the repairman verifies the size of the ends; a reputable repair shop should have some anodized aluminum test/sizing fittings to verify if it's SAE or metric....
