Which engine?
bigtard10
scottsdale az
I know its not military vehicle but its pretty **** close, might make it into a cucv clone. I have a 1977 chevy blazer and I am day dreaming of which engine I would want it in the the future. It's between a LS9, Chevy ZZ575, or maybe even a Duramax? thanks!
VPed
303
Clint, TX
How about a Cadillac 500 cu.in. torque monster? Good for lots of low end torque. Even with buying an aftermarket TBI injection system for drivability, it would be cheaper than the alternatives listed above. Big torque motors do not need lots of gears so a TH 400 with moderate gears in the differentials should do fine on and off road.
richingalveston
120
galveston/Texas
If I had the money, it would be a P-400 in front of a 4l80e with a hero 3 speed transfer case.
Those three pieces will cost you about 15K but will bolt in without any serious cutting. It is still probably cheaper than a d-max with Allison install.
This would be my long range after I win the lottery plans.
Rich
11Echo
92
CT W. R.
The 1970-71 Eldorado's 472 inch engine were Cadillac's best carbureted motor. There are companies with ready to bolt in motor mounts and some have flywheel/clutch setups for manual transmissions. Look around.
evldoer
Leroy WI
If you have deep pockets the ls9 would be fun. Something a little more in the average guys budget would be a 6 liter.
I'm doing a conversion on a customer's 85 chevy civvy pickup using a 2009 ly6 6.0 engine with variable valve timing and the 6l80e transmission. Relatively easy swap, as far as ls conversions go. I think The 6 speed auto will really be nice in an older truck. With the right tune this engine should make 400+ horsepower.
The ZZ572 would be fun also, but might not be much of a daily driver
